Aluminum boat cleaning can be easy. If you have the right products and time, anything is possible. I came across this video below and I wanted to share that shows how you can restore your boat very easily without a ton of work. For those of you with bare aluminum boats, this looks like a no-brainer. The best part? This aluminum brightener is dirt cheap. You can get a gallon for less than $20.
The name of the product is Purple Power Aluminum Brightener. You can buy a gallon of this stuff for under $20 and it’s available almost everywhere. I’d like to thank PUT EM DOWN Productions for making this video. Subscribe to that channel as he has done some other cool mods to his tracker as well.
We know aluminum boat cleaning can be a chore, this stuff makes it easy.
Oliver says
Star Brite Ultimate Aluminum is also a good cleaner, It Great for polishing aluminum material and getting the shine back and It can be used for other types of boats aside from just regular aluminum pontoon boats.
Oliver says
Aside from that, Star Brite also comes with a sprayer, making it really easy to use.
Roe Gary says
I tried to clean the tubes with all the cheap environmentally friendly suggestions that a lot of people suggested on the forums. These didn’t work for me. Over the winter I ended up buying this STAR BRITE Aluminum Cleaner and it worked great. Sprayed it on and lightly scrubbed with Scotch Brite pad. Waited a few minutes and washed off with hose.
